nad said:I cant use that distributor without comp.? Was told I could.
dan2286 said:nad said:I cant use that distributor without comp.? Was told I could.
The advance is controlled by the computer, so it might work, but not good. You would need to get an earlier style HEI with vacuum advance.
nad said:Would I be better off with the stock 83 h/o 307 stock intake than the offy? All I know about motor is 69 350 #5 heads, bored 30 over comp. cam slightly over stock, 670 street avenger carb.
