FE3X CLONE said:Check the filter for an LS1 in an F-body. I had test fitted one on my engine looking for something smaller and know it worked but was WAY too small for my liking.
Might work for you.
Fram lists the below dimensions for a PH3056:
3.36"H x 2.98" OD
DoubleV said:FE3X CLONE said:Check the filter for an LS1 in an F-body. I had test fitted one on my engine looking for something smaller and know it worked but was WAY too small for my liking.
Might work for you.
3.36"H x 2.98" OD
That part number isn't turning up anything for me.
jrm81bu said:A 1516 Napa Gold is a popular filter. Has 3/4 16 threads and is 2.9" in diameter. There should actually be a lot of part number that fit the criteria you listed. The F-Body one would work as well. Is there any other requirements you're trying to meet with it?
