I HAVE AN 82 OLDS CUTLASS V6 3.8 IT'S LEAKING OIL LIKE A RIVER BY WHERE THE OIL PUMP IS, BUT IT'S NOT COMING FROM THE OIL PUMP. ANY IDEAS???? PLEASE HELP
how many mil on the engine ? it could be many of things like worn rings causing blowby causing crank case pressure or bad pcv val not realising crank case pressure need more info 🙁
