okay so im a bit disapointed. i built my 350 and test ran it on a stand in august to check for oil leaks. i had none. so the motor went in the car. so i got it running before i found out about my header issue. now theres a puddle, not really a puddle but 2 spotsunder the car. its just really upsetting being its a brand new motor. looks like it might be from the pan rails since its two spots of oil one on each side of the motor. how do i fix this, can i just try and tighten them a bit more or do i leave it or do i pull the pan while its in the car somehow and change out the gasket. also if that is the case is there a 1 piece gasket that seals better?
