Oil pressure light on
X2 on the lucas oil stabilizer. i use it in my flat tappet malibu. its as thick as molasses. its suppose to extend engine life, and i have had a handful of mechanics say to use it, so i tried it, and it seems to run better... also use it in 2 backhoes, 1 dozer, and an excavator... as for my new full roller 350 sbc, i am trying something different, going to run the same kind of oil for the entire life of the engine... the pennzoil platinum that is made from natural gas, 10w-30... and a fram filter... heard it keeps the motors exceptionally clean, which i guess makes sense, normal oil is refined from dirty crude oil, the natural gas oil is made from clean gas... but, only time will tell...
A couple of observations about the functions of engine oil;
Oil is used to lower friction, maintaining a film on bearing surfaces is obvious, removing heat from the bearings is perhaps less so. Excessive heat will break down oil, and may cause bearing clearances to close to the extent that oil might not be able to form a film, or expand to allow hammering. A thinner oil will remove heat better than a thicker one, in a perfect world the oil in your engine would be just thick enough, or with enough viscosity to be strictly accurate to maintain a lubricating film and shift as much heat as possible.
Different engine designs have different lubrication requirements, one size most definitely doesn't fit all, although in the real world a quality gasoline engine oil will be fine for most modern gasoline engines, but a flat tappet engine will need zinc additive, a pre war L head loose tolerance engine won't like modern 5w30 oil either.
Oil breaks down over time, and multigrade oils in particular suffer from shear degradation, for example 5w40 will behave like 15w30 if you don't bother to change it for 15,00 miles or so. Multigrades with closer viscosity indexes suffer less than oils with wider spreads, 10w30 staying in grade longer than 5w50 all else being equal.
I know nearly all users of this forum are probably very conscientious about changing oil as well as other aspects of proper maintenance so I'm preaching to the choir here. However over years of maintaining cars for a living I have found using oils recommended by the makers has worked just fine for long and reliable engine life. The difficulty anybody in the old car hobby has is getting lubricants suitable for outdated engine designs, from flat tappet engines to ones built 100 years ago.
Roger.
After spending the weekend reading on Bobistheoilguy.com website. I am more aware of the importance the role proper oil plays, and even more confused on what exactly I should be using lol. It's no secret the majority of wear comes at start up. That said, I can't see where an additive that is thick could be very helpful at stat up. I'm sure the protection an additive adds is at operating temps. New oils offer plenty of protection that the old formulas never had, with the lack of zinc(flat tappet)being an exception. As for my particular issue being an idiot light coming on, I'll have to wait until I get a gauge on it. If I see I am within spec at 1lbs per every 100rpm I'll know all is well...I did look at a few "High Mileage" oils that are on the market, one of them, Quaker State Defy synthetic blend says it even adds extra zinc in the formula. I never got around to see if that is a standard with the High mileage oils or not, but thought it was interesting QS did that. When I was a youngster, my first car was a 66 SS Impala with a sbc, it had a canister on it it. I remember just putting a toilet paper roll in and the cheapest oil I could find and off I go. Life was so much more simple back then. 😀
Charlie, was the oil canister an add-on on your '66 Impala? I recall when I was a kid, we played around with a '56 Chevy 265/ 3-spd. The 265 V-8's had the oil canister that held the filter element instead of the screw-on filters that we typically use now. I don't think they continued it on the 283-327 engines.
My 4-cyl Porsche has the oil canister which takes the same elements as a Studebaker and some early Mercedes.
I know back in the day there were aftermarket filter canisters available that used diatomaceous earth. They claimed that you can go thousands of extra miles without changing your oil.
Jack the canister almost would have been an add on, not sure really. I got the car @ 14 from a friend of my dads. He was a rodder guy and had lots of sbc motors and parts around his house. He cobbled this car together using he said a 300hp vette motor. It did have camel humps, vette manifolds and a factory alum intake. It ran like a scalded dog. 12 bolt posi 2spd and I would be guessing that it had much greater than 3.08. :mrgreen:
That's why you should use as thin an oil as will effectively protect the engine at normal operating temperature. You need oil to get round the engine asap, a thin oil will do this quicker than a thick one.
Indirectly concerning this thread, if you decide to fit gauges I recommend keeping the idiot lights both for oil pressure and coolant temperature. You will notice a light a lot quicker than a needle moving from its normal position, particularly if you are in heavy traffic and concentrating on the road rather than your dashboard.
Roger.
Update: I got my mechanical gauge hooked up along with a new sender for the dash light, and I'm pleased to say that I find no issues with oil pressure. Cold start is 80psi, At highway speeds it's 44psi. At a long hot idle it never dropped below 14psi. I don't have a tach(yet)but I'm guessing my idle speed is around 750-800rpm so I'm well within spec on this...Now to go back at fix the new oil leaks from all the new plumbing :shock: , it has a very slight leak at the base of the stand off, and another on the base of the tee fitting. Worth the minor headache to know I have good pressure. :mrgreen:
That's good to hear, Charlie.
I know you've been going thru some anxiety about your oil pressure. I'm glad it's given you some relief. Those are some healthy readings.
Where are you mounting your gauges, by the way...in the dash?
See man i told you that you had nothing to worry about. Those older dummy lights everyone ive ever had just came on whenever they felt like. Even on a car that i had the oil pressure gauge pegged out when cold and around 60 when hot that idiot light still came on lol thats why i dont like them.
So glad to hear that everythings ok 🙂🙂
Yes Jack, I'm relieved to see the normal pressures.
I'm not that talented to mount them in dash. I pulled the ash tray mount and mounting the oil, water and volt in the autometer pods. I'll have them angled and tilted up towards driver. It'll look real good when done. I never ordered the water or volt yet. Thought I better see what I got to work with before I commit any further. Ordering the others soon :mrgreen:
