olds 307 coupe A/C and AIR pump bracket help
gp02a0083
308
16
hey guys, in the middle of replacing my water pump i didnt take note of the way the a.i.r pump bracket attaches with the a/c pump. I have the front bracket in front of the ac pump bracket. on the back side i have the spacer as seen in the picture followed by the air pump bracket. however i noticed that with it this way the a/c pump is angled slightly and not exactly in line with the water pump and crank pulleys. My question is really where does the air pump bracket bolts to? I was thinking that it might go between the support bar and the a/c pump bracket but i'm not sure.
I figured it out, nothing looked lined up until i started tightening stuff down. Turns out the picture i have originally posed was the correct orientation of the spacer and the bracket.
