OLDS 350 DIESEL
DROLDS84
464
788
Northern Indiana
Found a complete olds diesel with transmission that runs for cheap.Anyone know if the pulleys and power steering pump are the same as a gas 350? Needing pulleys and ps pump for a v6 to v8 G body swap.
As far as I know they are the same from 307 ,350, 403 but years may change a bracket by adding the air pump but should work out.
Always wanted a olds diesel engine thought it would be a different cool since I was running an olds 350 then a olds 455 10 plus years ago
Keep us updated on the project and post pics
Will do...waiting for some warmer weather.Kid decided to go back to school so he doesn't have full time pay to put in the car.Hopefully it will be running and driving this summer.
So are you building a gas engine out of the diesel or keeping it a diesel
Seems I remember hearing to save diesels for conversions. The blocks were heavier, better castings IIRC
Reactions: Tuffregal83
The power steering pump is different it's for a hydroboost but all the brackets and pullys should be the same FYI I'm looking for one of those pumps if you want to let it go
the 350 dx blocks make good 440 strokers.
Reactions: Clutch
