Thanks everyone for the advise/input! very helpful!
so i ended up picking up the 72 long block ended up being a 2bbl.seems real clean and turns over by hand
real smooth. i pulled the valve cover off on the drivers side and poked the oil valley (?) closest to the waterpump
and it seemed to be gunked up a bit ( mabye bc the motor has been sitting for a year? ) the other valley
closest to the flex plate seemed alot better. other wise looks good so far, going to dry and wet compression
test it to see whats going on then pull the heads to ck the cylinder walls and the condition of everything elese.
In reguard to the intake, i got a edelbrock performer..should have went with the rpm but i had intensions of
putting it on my 307.
what i want to do with the motor is if all is good with the bottom end ill just keep it stock and possibly bearings/rings
and the top end is where i want to focus,,get the heads done, nice cam, roller rockers/lifters. pushrods. pistons?
any advise or any combo to suggestion?
