You sure did😁. Pretty warm in my garage. I probably should wear actually shoes or my work boots when I install the 330 crank tonight💡.NICE !
Did I spot Safety Sandals ?
Yes but that one happens to be the worst. I think Mahle rough machined them there because they are coated. They are a nice piston otherwise. I actually had to remove that piston. It should have been right but was not. It appears the Molnar marked side is the wide side. The next rod would not go on the crank. I went to the other cylinders, paired pistons without rings and sort of put on the caps, they all fit as they should. I numbered them for each cylinder they came out of. I may just have to flip cylinder to cylinder. I will remove the rings and check those two as well. Only a minor setback, I want this build right and to live a long life.I need to ask, do all the pistons have this imperfection or they way it was machined in this area that's circled. When I look at that picture it looks like a piece of piston missing and I know it's not.
Your doing a great job putting that engine together, l like that you planned it out and taking your time.
Ok, I have a better understanding what they did, never seen that before on a new piston.Yes but that one happens to be the worst. I think Mahle rough machined them there because they are coated. They are a nice piston otherwise. I actually had to remove that piston. It should have been right but was not. It appears the Molnar marked side is the wide side. The next rod would not go on the crank. I went to the other cylinders, paired pistons without rings and sort of put on the caps, they all fit as they should. I numbered them for each cylinder they came out of. I may just have to flip cylinder to cylinder. I will remove the rings and check those two as well. Only a minor setback, I want this build right and to live a long life.
