G-Body_Vet said:79loserbluebu said:I've never heard anything about steam holes, but you'll also need to drill the locating pin holes on the heads slightly larger for the pins on the 403. You'll also need the valve covers with the correct number of bolts.
I could be wrong, but I thought the 403 heads had the steam holes similar to the Chevy 400 because they're both siamesed cylinder blocks. I don't want to give out the wrong info, so feel free to chime in.
We didn't drill any steam holes on my brother's 403 when we swapped to the 7A heads. Just drilled out the head bolt holes for the larger head bolts and like you said, enlarded the dowel pin holes slightly.
