My mechanic buddy told me the best solution in a case like my swap is to mount the trans to the crossmember, put the mounts on the engine, install the frame mounts to the motor mounts, lower the engine down, level it...and then weld the frame mounts in their positions and be done with it....maybe I should have followed his advice!two90west said:wow so i wanna just say the mounts in the first pics are WRONG, i guess monday i will pull the motor out and flip the driver side mount around. thanks for all the input keep the info going for guys who need it GBODY4LIFE!!!!!!!!!!!!!!!!!!!!!!!!
true....but some swaps require frame pads to be mounted where there are no holes available or custom made pads and once the engine is in, theres not much chance of removing them and rebolting them into place... of course you can always drill out some new holes, but that would require removing the engine again......just my 2cents...lolFE3X CLONE said:Never ever weld your frame pads to the frame! It's not that hard to just bolt them in place.
Although I did weld all of the non-essential engine mount holes in my frame so that I can say this car is an OLDS ONLY chassis. 😛
