Hello all. I just broke another set of motor mounts. This makes 3 since 2013, when I swapped my '73 Olds 350 for a SBO 307. The stock 307 mounts snapped a week after the swap. After I replaced them I wound up having a funeral for the 2004R. It's been T5 since.
I had this problem back in the '80s on my '71 350 Cutlass and I used cut chains tied to the end head bolts and to the frame. That car launched pulling the pass side wheel off the ground.(Suspension tricks helped achieve that feat. ) Meanwhile, I've tried buying new mounts from earlier years for my '88 but the results were the same. No room for chains on a Gbody Olds with full accessories, so I came up with a simple fix.
I made a strap that bolts from the block to the frame mount using the motor mount's holes. This way the straps stop the motor mounts from pulling apart. Kinda like a solid motor mount. But I'm only using the straps on one side of the rubber mounts to absorb vibrations.
Warning, I do see these straps eventually shearing (especially on 455s) but they are relatively easy to make and replace. So follow my lead with caution. Like the HotDog vender on the game Grand Theft Auto 4 says, "I'm Not Liable, Enjoy! "
