Yep....that's a pretty nasty pile happening right there :lol: I'm afraid to see what's in the bottom of the pan and the pick-up screen
rccktmn2 said:The common olds block big or small will survive very well below 5-6000 rpm, anything above that (on a stock build) and you will have some problems. The other theory is that the (not a theory) 403's are weak blocks because of the "windows" in the main webbing of the block, and that is why they make (poor high revving) performance engines because of weak mains and poor oiling. I've had 2 of these engines and never had a problem, the pistons are huge and as long as your not going to extremes (500 hp and up) you should be fine.
I'am confused :? if you change your oil regularly whats with the sluge. Can some one please explainG-Body_Vet said:Got bored and decided to yank the pan and a main bearing to get a better look. The pan was nasty but there wasn't as much sludge on the bottom of the engine as I was expecting. The bearing shows a little wear from dirty oil but that's it.
I think I'm going to button it back up, save it for another project and continue to forge ahead with the 455 instead.
DRIVEN said:So what ever happened with this?
