Went to open the door on my 1988 MCSS and the the outside door handle seems loose. Not as much tension on the handle when you pull up on it. The door still opens when you pull up. The handle just doesn't have the same tension on it.
So what might be going on? Is it the door handle itself or do I have a problem with the door latch mechanism.
I know I just need to dig in but wanted to have some input before tearing stuff apart. Thanks for the help.
