P/S Pressure O Ring Installation?
MrSony
6,545
Des Moines, Iowa
How is the oring installed? Does it sit on the flange of the hose? Does it sit in the fitting in the pump? I've had a persistent leak coming from this area (even after I've resealed the pump, the reservoir o ring is NOT leaking) and I also don't think I have the right size o ring. Any info is appreciated as always.
79 USA 1
990
Cheektowaga, New York
Having worked for a local aftermarket brake and fuel line company (Bent on deception...Sorry, I meant "Bent on Perfection") The O-Ring is installed on the flange of the tube of male fitting (Red Arrow).
I had made thousands like the photo below for a well known and respected steering parts manufacturer. The O-Rings we supplied were about the same OD as the flange they seated against and fit snug over tube.
Most important is never install them dry.
Hope this helps.
  • Informative
Reactions: 5 users
