View attachment 51051 View attachment 51052 View attachment 51053 View attachment 51054 View attachment 51055 View attachment 51056 Good news is I installed my dual fans, to the shroud and all to the new radiator, and got it mounted in the car. Bad news is that upon firing the car back up and filling back up with coolant, my thermostat housing is leaking (I just put this new one on last week in preparation for the radiator install); this is the 3rd time in as many attempts that the housing has leaked. First was with a chrome (junk) water neck, Felpro gasket and no sealer, 2nd attempt was with chrome water neck, Felpro gasket and sealer (Permatex), and the third was with the new OE housing form Fusick's, with Felpro gasket and Permatex...I've never had a problem with the housing leaking before, and I know everyone has a differing opinion as to whether or not to use a gasket sealer/maker..but I've done it both ways, with two different housings, all on a new Performer RPM intake....I wouldn't think the surface is gouged, and I don't think I've over-torqued the bolts causing any warping.....but I am at my wit's end. Just something else to deal with, I guess.
It's good to see you, it's been a long time since I've seen you here......are you sure the intake isn't cracked
