Oh sorry, I read that wrong! I’m not using a boost controller, just running off the wastegate.What are you running for a boost controller? 3 or 4 port MAC valve?
Can you suggest a particular one? I definitely have considered this.
Also how do you control the tune with one of these, my tuner said it will be a different tune as you go up in boost, I would assume it works both ways?
Thank you 😊I would suggest checking out our savory, Matt Happel. He has some great videos on boost control. I am using a Holley TerminatorX so boost control is built in. I think on the factory harness you will need to buy a separate controller.
Also, the tune should adjust for the boost levels. I think you need a new tuner, sir.
