81 Lemans, factory master cylinder, factory front disc, GM 80's rear disc calipers, factory brake valve replaced with Wildwood adjustable . All new lines, hoses, reman calipers. So the pedal goes to the floor , release and reapply pressure and it holds good ? I thought maybe to much slack in rear pads, so I hooked up the park brake cables and applied the park brake, pedal still goes to floor on first apply ?
