I bleed them again the other night. I think all air is out, but at this point I may try it again, although it definately looks like rear Pistons are retracting too much.Have you checked to make sure there is no air in the rear lines?
I turned it out fully, giving full pressure to the rear, doesn't fix the take-up issue. Seems to be an excessive amount of play in the rear pads? That's why I was thinking the 2Lb valve is no good , or need a higher pressure one ?Assuming you tried to adjust the Wilwood proportioning valve on your set up that adjusts line pressure to your rear brakes did that change anything?
