performance buick 350 ?
loneSTRregal
20
35
Highlands , TX
Ive been surfing the net and forums , trying to find out about building a performance 350 buick . I know the 350 buick is weaker then other gm 350s . basically I cant find parts for one and really havent run across any hot rod 350 buicks .
any help woul be great
Check out http://www.taperformance.com. They specialize in Buick performance parts. The only real disadvantage to a Buick engine is the price of parts. On the plus side, Buick blocks have a high nickle content in the casting. This means they are lighter and stronger than say a Chevy block which has almost no nickle. A 455 Buick big block in stock trim only weighs about 50 pounds more than a small block Chevy. :banana:
You can download the TA catalog from http://www.taperformance.com/PDF/TAPerf ... atalog.pdf
If you're really interested in doing a Buick, TA performance is about the only vendor I know. Kenne-Bell on the west coast was a Buick-only specialist for years, but have since moved into supercharging of all makes. IMO, a Buick 350 doesn't make much sense from a bang-for-the-buck standpoint. A 455 is no larger, no heavier, parts are the same price and more available, so you essentially have 100 extra cubes of torque with no downside. A few drawbacks: Performance parts are generally more expensive than Chevy parts due to fewer suppliers and much lower sales volume. Also, Buicks are notorious for oil pressure issues. The aluminum front cover serves as the housing for the oil pump gears, and wears with use, limiting oil pressure. I understand TA is now selling newly cast front covers, but I'm sure they're not cheap. The main bearing diameters are much larger than a typical Chevy. Combined with marginal oil supply ,the large mains make high revs a really risky venture. But Buicks are all about torque, tons of it, from idle up to about 4500 rpm. Build a mild 455 with a conservative cam, decent exhaust and you'll have a street motor that will make you happy. Having done a 455 for a friend's '37 Chevy, I applaud your intentions. Just do your homework before you make any moves.
Bill
Ditto TA performance. PG's in Brooklyn does Buicks too, but as stated it's a lot of $$$$$. I fixed up a Buick 350 in a 68' LeSabre (grooved bearings, oil pump kit, cam) and it was sweet. However, a bone stock 455 out of a land yacht will make a Regal practically fly. Forget Chevy-think. You don't have to do much to wake up a Buick and it will last a long time.
