Picked up an 87 Grand National clean title car with 98k miles from NJ. VIN checks out as does the RPO sticker / WE2 code. The car is a bit of a mess, with the wrong trim bits on it, rotted areas on floors, areas cut out of the rear driver fender, doors not in good shape with holes along the bottom, and original drivetrain is gone and an incomplete LS swap sits in it. Frame looks solid, most body panels look decent, trunk is solid. A lot of the wiring has been modified due to swap, unsure if the motor and transmission are operable (5.3 LM7 + 4L80e with no driveshaft). Not sure what condition the brakes are, and how ready the fuel system is.
How would you guys approach this project?
Work on the floors first? then drivetrain?
Before I get the motor running, I want to paint the engine bay which will be a good bit of work on its own removing the inner fenders, other metal bits, preparing everything, and priming / painting. I have never done metal work or welding. I am hoping to buy a mig welder and learn on the floor.
And the floors:
Driver side looking forward, rotted area:
driver floor looking rearward:
passenger floor looking rear, soft area:
Areas of floor pan suspected to need replacement:
And the floors:
