Thank you for the very detailed photos. I think we’re all good. Yes I’ve got the little metal nozzles and will probably stick with it. Some photos of what’s going on/the car
Thanks!
Thanks!
NICE JOB!!These clear enough ? If you need anything closer let me know. View attachment 139652 View attachment 139653 View attachment 139654
Thanks!
Haha, it’s good from afar but far from good, thanks though.Welcome aboard! Looks like a nice clean body Other than putting it back together, what are your plans for it, and what are you using for a drivetrain?
I’ll share more history when I have a build page going or in a minute.
I thought I had this sorted but I put in the wiper motor and nozzles yesterday and the area marked has nothing behind it to bolt up. In the photos from others there’s a bracket or something there or at least a bolt inserted. Yes I get the wiper stops location but they’re in a different spot without the circular relief. I know I’m going ocd on this but is it possible this is from a different vehicle?
Yes washer nozzles are good...Each nozzle should have a bracket soldered to it for fastening...are yours complete?
Now we’re getting somewhere...If theres nothing there to screw into do you have the two brackets that are held onto the firewall with nuts ? Right where you drew the circle theres a bracket under that wide trim. Theres another one to the left of that. Theyre held on with speed nuts and the trim attaches to them.
Maybe thats the problem ? Or if theyre there you might have to loosen them, fit the SS trim and tighten the nuts back up.
