On Chevrolets, "1980 only"* used a thermostatic vacuum switch to a vacuum/electric switch for lockup engagement. 81+ were done through the ECM.
* US market, gasoline engine
Hope this diagram helps, should show you how to wire it through the brake lamp switch to avoid stalling when stopping, and avoids the use of a toggle switch.
FWIW, the fender mounted switch on 1980 A/G body Chevrolet cars was on the left fender, about halfway back...on the steel inner portion, not the plastic liner.
