14mm is slightly tighter than 9/16. 15mm is slightly looser. If you crack another Craftsman, try an impact socket instead (black, thicker walls). You won't crack that.
Oh, and if you run without the flexplate and it comes loose or shatters, it can slice right through the transmission case and the floor of the car to take your foot off! Not a good idea to go without it.
