I was helping a friend with a fresh Chevy 350 and when it came time to adjust the roller rockers, it got messy. His place, not mine, so no proper tools and extra parts to help. Normally I like to adjust them dynamically with the engine idling, with the clips in place, or a cut down valve cover in place to catch the oil. His engine had a tunnel ram with dual quads that couldn't idle below 1500 rpm and the rockers had an oil discharge hole that squirted oil right at the lock and the rocker flung it right over the side of the head onto the headers. The clips didn't fit these rockers, and we had no gasket for the cut-open valve cover and the cover bolts had long shoulders to secure the wire looms so they were not clamping the cover down and oil poured right past. The oil smoked like the burning oil wells in Iraq, so I decided to adjust the poly locks statically and hope for the best. After having him bump the motor over and watching each rocker open and close I adjusted each lock to zero lash plus 1/4 turn, which is normal for a running engine. With the valve covers on and the engine running I could hear the rockers ticking a bit and I am sure I should have tightened up the adjustment more, but how much? This month's Hot Rod mag showed a static adjustment of zero lash plus 3/4 turns. Is that OK or too much? I know on a running engine that's too much, but what about a non running engine? How do you guys do it?
