The bushings in my rear control arms are smoked, would like to upgrade to some poly bushings, where is the best place to get them at? Are they hard to remove / install - do they require a press or can it be easily done with simple hand tools?
shotgun said:I believe that GM number is long dead or at least superceded with only one bushing available.
Also use 2 non poly bushings in the uppers, in the rear ears, they need to be able to twist on a street car.
shotgun said:Also use 2 non poly bushings in the uppers, in the rear ears, they need to be able to twist on a street car.
