If I can get my stupid phone to load the finished product pic you can see how well it turns out. Note, the stuff we use is NOT UV sensitive and will NOT fade if exposed to sunlight!
If I can get my stupid phone to load the finished product pic you can see how well it turns out. Note, the stuff we use is NOT UV sensitive and will NOT fade if exposed to sunlight!View attachment 56802
Hope you have some earmuffs....them needle scalers are definitely noisy as hell! Like 565bbchevy said, go to harbor freight and pick up a pack of chip brushes, toss them after one use. If you have any paint leftover, put the lid on and put in a good sealed ziplock bag and put it in the fridge. I know it sounds crazy but it works!Looks good! As I said before, I'm using an air needle scaler to knock the rust and scale down. It works great, but it's very noisy and it takes a toll on your hands. It does great at getting into all the tight spots an angle grinder could never reach.
My frame has some holes in it that have to be plated & welded up before I paint, so Ive got some time to research into the acid metal prep while that's being done.
PS- I did buy a quart of the POR15 brand solvent as I've had some bad reactions with paints myself.
That's what I meant about putting a bag over the can but typed it wrong, hit reply then saw it after lol! I've only sprayed the aerosol version of it. Very finicky as it will run quick...it lays down like ceramic brake paint which makes it easy to see what spots have more or less paint. My bodyguy sprayed a chassis of a Willys jeep but used the POR15 reducer and it turned out great!wear gloves! the screw tip above is a good idea! i put plastic over a open can then out the lid on, yeah throw away the brushes, they get sh*tted up after using them a while anyways.
anybody spray it? i never had the nerve
been using it a long time
