I would put one on these cars, I have one for mine and it probably only makes 100hp at the wheels, it's not like you are talking a huge money investment. Every GM gear set I have ever done for me or other people I have put a cover on them, the gears in the above pic are two laps old in a heat race, you are looking at over $700 in junk for a broken cap. If you use a girdle cover, c-clip eliminators, a decent aftermarket axle, and jig up and weld the tubes so they don't spin, these rears can easily handle into the 11's /475hp. If I personally was to ever change out the housing in my car for more power I would go to a 9" only because of the c-clip GM stuff, the eliminators like to leak. The biggest thing I see on GM rears is guys don't get the pinion depth right, if your new to it GM rears can get frustrating because you have to handle the whole housing to set it, and keep pressing off the pinion bearing to change the shims, another reason the 9" is the better choice. With the bolt in 9"'s available today spending over $1,000 for a 8.5 just to get a ring gear that is a little bigger doesn't make much sense to me IMO, the pic shows a 9" case but it shows you don't need any expensive tools to do pinion depth, it's a cheap depth mic and a parallel bar, not the way I do them the pic is from a "class" when I was showing a guy how to do his own gears without spending big money on all the equipment that I have
