Power brake booster advice plz
1STLATIGERDIVISON
123
20
NW Louiwiana
I recently had to rebuild my 350 in my 88 SS/MC. In doing so with installing a 278 cam I lost vacuum in the booster. The booster requires 18" of vac it's getting 8". The OEM isn't cutting it. So is there a type vac booster ( hi preform) available that can possibly solve this problem. Have looked into vac pumps most all I read they are noisey but work somewhat. Hydra boost works well but expensive also understand if the car loses hydraulics so goes the brake & steering.
Plz would appreciate all recommendations or solutions
Regards & thx to all
Gary
Ribbedroof
4,920
7,045
Wellston, OK
Engine driven vac pump. Will require fab skills, but stops my F350 just fine.
9,618
12,699
I am running a belt driven vacuum pump off a 95' Ford F350 diesel, I just made brackets to mount it.
It pulls 28" of vacuum and self regulates itself and does not require a vacuum source and since it is belt driven it is always on.
I bought mine from a junkyard about 17 years ago and it still works great and with my set up my car stops exceptionally well using this.
Ribbedroof
4,920
7,045
Wellston, OK
The original on my truck went over 300,000 miles....built Ford tough lol
But not near as pretty as your installation.
