looking for any information on what I need to put power steering back in my 1986 buick regal. Any information would be greatly appreciated. thanks
its a sbc 406What motor? Depending on that, you will need the PS pump and brackets for your particular motor, the belt, the hoses, and a PS box with the Pitman arm for a G-body. Stick to the 800 series box with the 4 bolt top cover as they are plentiful and reliable. If you get a junkyard box, be sure to grab the 3 long frame mounting bolts.
all the components u mentioned above is all I need? I wanna make sure when I do end up doing it. that I have all the parts I needWhat motor? Depending on that, you will need the PS pump and brackets for your particular motor, the belt, the hoses, and a PS box with the Pitman arm for a G-body. Stick to the 800 series box with the 4 bolt top cover as they are plentiful and reliable. If you get a junkyard box, be sure to grab the 3 long frame mounting bolts.
