Re: Re:
I did it without removing the glass. It's a bit of a pain but it can be done. Takes patience and one of those little angle screwdrivers. IIRC I even had to use a small driver bit in a visegrips.
cashmoneyspeed said:joesregalproject said:I know this thread is 5 years old, but how do you remove the window sill chrome? I'm trying to figure this out without taking too much apart. I'd at least like to have an idea as to what I am doing before I do it.
Remove the door panel, then Remove the glass, now you'll be able to access the Phillips screws that hold it to the door. Great time to lubricate stuff and replace broken door panel clips to tighten things up.
