Basically I am looking for something like this but ones that will fit the o-ring style fitting of the ac hose end.
I know the molecules are larger than air but think of your statement...IT"S A MOLECULE! Impossible for anyone of us to see, measure the difference. If the system is sealed with Nitrogen, it will be sealed with refrigerant.Nitrogen is a larger molecule than air* So if you fill it with Nitrogen you may miss the leak.
As far as moisture goes from the air. The system should always be vacuumed before/during charging the freon.
So it's not an issue
I didn't ask and honestly I do not want to count on any outside source to do anything for me which is why I wanted to make my own hoses in the first place.Does the place you purchased the Good Year hose locally make the lines to??
Can they test them??
This style and the nuts are AN sizesO-ring like a power steering hose fitting?
Unlubricated of course unless...Tape a condom on end and fill it up!!
If the condom goes limp there is a leak!!!
