Project BigSmallBlock: 406/T-56 build ** MORE PICS
joey_schel
Feb 11, 2009
89
Stratford, Ontario
Hey guys, just wanted to post up some pics of my current motor/trans project, a small block 400 bored over, AFR 190 heads, comp XE284h cam, crane gold rockers, etc.
I'm also doing my own t-56 rebuild w/ bronze shift pads, steel 3-4 fork, billet keys and new synchros
Lots of negative rake without a motor lol
Rebuild Parts
My Shop/Work area (roommates cars- 91 Nissan 240sx, '83 VW GTI)
Main Studs
Nice honed bores
Crank going in
Checking endplay on the crank
TRW forged flattops, 400 rods
Me installing pistons (upside down?)
Wow.
The AFR 190's and the best valve covers ever :D.
Hit 'em with some ceramic flat black, then sanded down the script
The AFR's complete
Gear Drive. Was told its a Pete jackson, i dont think it is from what i've seen, could anyone help me here?
I'll throw some more stuff up here when i get it off the camera
woodie
5
Re: Project BigSmallBlock: 406 build
joey, i also bielt a 406 sbc for my 83 cutlass look in my profile. i had a set of peat jackson gears in it. started it for the frist tine uncap headers. my shop is about 50 ft from the house my wife came running out aksing about that awful noise was. to loud i change then to a double chaine. now its cap ands sounds great but is shacks tha pips of the walls and diches out of the cabines. now i just got to deal with her but she can wait to drive the car, its for the street i love it woodie
Nates84cutlass
19
2
Thomasboro, Illinois
Sweet, I just built a similar one. I did use a pete jackson, my memory says it could be a pete which isn't saying much. Looks good and I wish I took as many picks.
DRIVEN
8,112
14,668
*CENSORED*
That should be a strong running combo. The pan looks pretty deep. Is it going to clear the crossmember?
joey_schel
Feb 11, 2009
89
Stratford, Ontario
Actually its a stock pan, got it for ten bucks. You guys with the 400s, how fast is that motor? Im hoping for maayybe 500 at crank, thats optimistic obviously, but i've heard those heads are great so we'll see.
DRIVEN
8,112
14,668
*CENSORED*
The one I built for my El Camino pulls like a freight train. It was built for towing with low end torque in mind rather than high RPM horsepower. It's really nothing fancy.
-.060 over 4-bolt block (I know that .030-.040 is recommended max)
-stock #882 heads
-XE256h cam with matched valve springs
-Performer intake, 800CFM Q-jet, HEI, cheap Summit headers.
According to my Dyno2000 it peaks at 270hp @4000 and 440tq @2000. It maintains over 400tq until just under 4000rpm. I tried to be as realistic with my data input as possible. It will never see an actual dyno but I can tell you that it will lug down to 800rpm in high gear(manual trans) and pull right back up without pinging. The torque down low is almost diesel-like. Kinda apples and oranges compared to yours though. I think 500hp is a bit optimistic but you may be in that neighborhood for torque.
joey_schel
Feb 11, 2009
89
Stratford, Ontario
Woodie I'm sorry but i just can't understand some of your story dere.. Gear drive was too loud for ya?
Driven- I know they're usually known for being torque monsters, but im hoping to rev this one too. with these heads and cam, and a single plane intake on the way
joey_schel
Feb 11, 2009
89
Stratford, Ontario
Heres the T-56 tear down
I tore it apart mainly because 5th gear didnt want to engage at all. Once apart, found out the plastic 5-6 fork pads broke, thus allowing the steel fork to wear down as well!
Second gear also popped out on occasion, usually on a downshift
On the bench
Some of the necessary tools
The shifter cup
Tail housing off
Tail Housing
Reverse Assem.
Reverse is out
5-6 counter/cluster
Looks fine!
MidShift rail Detent assem.
Dont let that little shift detent ball spring out and bounce away on you! almost lost it a few times..
Main Case off..
Pullin the shafts out
Takin Bearings off the mainshaft
Synchros, bearings all off the mainshaft
Rebuild pics soon
83cutlassowner
207
2
yankton,sd
Love the shop poster. the girl in the reds very classy :rofl: but super hot
