Yeah he's really getting an in depth start for sure. He brags because of all his friends he's the only one that can do it. Have to keep the hobby alive.What a way to learn how to work on cars!
Pretty basic really, stock bore and stroke, luckily the bore was good enough to not have to overbore the block not that it wouldn't have been a bad thing. ARP head bolts as well as full ARP bolt kit, High volume oil pump, high volume aluminum water pump, Edelbrock SP2P 4 barrel intake, Edelbrock 500 CFM carb, Cam is a Melling grind with .474 lift intake and exhaust, duration 232 @ .050 on a 113 lobe separation angle. Double roller timing chain, STOCK valve springs (im sure those will be just fine... nope) Also the heads have been milled .030 to raise the complete crap stock compression. Cant forget the Thornton dual exhaust manifolds also. So it should be a peppy little engine that sounds like it has some balls but overall it will be just enough for a teen that he can show off his lumpy idle all he wants but he wont be trying to blow away any honda civics either. But i've been surprised before so it might actually make some power.What all the specs on this 260? Colour me interested👍
Flat top pistons so yeah probably 8.5 to 1 or somewhere in there, about the best i was going to get without some domed pistons and i just wasnt going to do that for a play engine.Holy sh*t, a W31 cam in a 260! Your vacuum will be the sh*ts, it wasn't enough on the 350! You gained 5cc on the heads, so what around 8.5 to 1 now? What is the factory piston dish?
