Push button wiring
565bbchevy
9,614
12,683
Michigan
If you have a remote starter solenoid it would be pretty easy to add a bump switch in the car to crank the engine but you still need the key on to give power to the ignition
Built6spdMCSS
5,804
9,715
Florida Beach
3 switches:
Main power on/off
Ignition power on/off
Push Button momentary switch wired to the ground leg on a relay for the starter
I've done it that way with no issues.
With so much stuff on google and youtube, take a look in there.
64nailhead
Goat Herder
Dec 1, 2014
5,709
12,216
Upstate NY
Pretty easy. Need to cut the purple wire and pink wire from the column that go to the ignition switch on the base of the column. Pink wire to a manual switch and purple wire to the push button.
Why do you want to do this? Building a race car? If not, then not recommended for the weekend cruiser.
abbey castro
1,048
1,318
Harker Hts TX
Push button start is cool on the new cars. My Audi has that but I wouldn't put it on my 87. Unless like someone has said, already is it race car? But it's your car do what you like not what we say:)
