Pypes, Jegs, Summit, which one?? 1/16/20
mandrel bend is a bunch of BS on a street car
You will never feel the difference between shop bent or mandrel unless your on a track with a time slip
3-5% gain in perfect conditions with mandrel bending
Look at it like a bendy straw, is it harder to drink out of a bendy straw than a straight straw?
If it actually is, you dont notice it while using it
Reactions: Injectedcutty
Like car speakers! :banana:
Injected, build it for the future, so you don't have to backtrack when the turbo(s) go on.
I'm not looking at mandrel bent tubing from a performance standpoint, more of an aesthetic thing for me. I know the difference is not noticeable, just looks way nicer. As mentioned in my build thread, this is a street pounder/ show car so every aspect of the build needs to be cohesive.
Nothing wrong with a shop built exhaust by any means, I've had several, not this time though.
That is something I forgot to mention in the original post. Obviously turbo(s) don't really need mufflers, it helps to stealth them down some. Still undecided on a single or twins, I'll cross that bridge when it comes.
Show me how you can build a 2.5” or 3” exhaust out of stainless for $549. Go to your mom and pop muffler shop and ask for this and watch them 1) say they cannot do it, 2) kink the s$$t out of your nice stainless pipe, and 3) charge you double the price for their half a$$ work. Buy the Pypes system! Change mufflers if unsatisfactory and still be under $750, which is the cost of the other system that you’ll get 100 different opinions on.
You can't; I was just throwing it out there. Like I said with my kit on the 67, I didn't like the tailpipes, so I chopped them up to make them fit the way I wanted.
The discussion about aftermarket parts not fitting has been had here several times. It's all about your mindset going in. I approach aftermarket parts assuming they won't fit, and I'll have to make adjustments. You only get frustrated assuming they'll bolt right in. It's a pleasant surprise when they do actually fit the first time.
Get the Holley 3" system. Look at how much time I spent fitting the Pypes system to my wagon. Turn a trick or two if you need the extra $200 - beats all the residual *ss pain and frustration from working with a sub-standard kit. I have a 3.5" DS in the wagon with 3" tubes... you'll be fine.
Not a fan of the pypes system, saw no improvement, it will be coming off. As mentioned your not pushing a lot of HP, size won't be a factor. Don't let a few bucks dictate what you really want.
Reactions: Texas82GP
