I posted about one of my Q'jets flodding last week and thought I found the issue with a metal chip stuck on the needle. Yesterday I decided to try it out and it flooded again just idling. So I opened it up today and tested the float setting by filling up the bowl and checked it. It was fine. I blew into the inlet and the needle held fine but cheching on that people blow less than 1.5 lbs so that test is NFG. I tested it by sitting the carb on the inner fender with the horn off and the fuel line hooked up to it and turning the engine over using my bypass with the ford style solenoid. Held down the rod that holds the float in place the needle stopped the flow when the float hit it's level and it held. I put the gasket and the horn on and tested it again, didn't flood and the float was at the perfect level. The only thing I can think of the carb flooded while the car was running so possibly the fuel is able to sneak by with the slight vibration of the engine running......so next step is to put in a new seat and needle.....🙂
