Okay guys i'm lost here and looking for some advice. I have a early 70's qjet that i bought "rebuilt" from a guy, well it ran pig rich and couldnt lean it out at all. so i took it to a shop here in Indy and they went through it again, found the choke linkage was bent as well as the wrong float was installed and was sticking. well they got it back together. i bolted it on my 455 (bored .030 with a 230/236 and 112.0 lobe sep) and it fires up, idles great around 850-900rpm. put it in drive and it stays around 650-700rpm until the engine is hot (above 180) then in gear it starts to bog out and almost die. I can power brake it and it will stay running... let off and it will die down again and barely stay running. put it back in neutral or park and it does the same until i bump the rpms up and then itll idle again just fine. shut the car off and then go to restart it and you have to give it some gas to start back up again. i'm kinda lost on where to look next..... not sure if its a carb issue or possibly an vacuum advance issue on the distributor. this only seems to happen after being in gear and driving. itll idle in park no issues at all other than smelling just a tad rich. short of sending the carb off to be rebuilt again(this time by everyday performance)...... im not sure what else to check. The distributor is used, it was in the engine before rebuilding it. only thing thats been done to it was I put in the pertronix HEI tune up kit. i never changed the springs or bushings in it though. and when i set the timing, with the advance unhooked and plugged, the it is about 12*before tdc on the timing pointer. seems to like it there the best and when i hook the advance up, it idles great. i dont believe it is a choke issue but i could very well be wrong too. anyone have any pointers or ideas on where to start? getting tired of just throwing money at it with the same results.
