Ok this is my first post and the second time typing it as when I tried to attach a pic it deleted my entire post. Gonna try to list things so its easier
stock internal 305 from 86 Camaro'
new vac advance HEI
all vac ports on carb plugged
air pump removed
emmisions crap pulled
feedback style qjet
30 degrees total timing right now
Detent cable for turbo 350 still in place
Car runs great under throttle or in Park. Drop into gear still running good. Drive around and then come to a stop light and rpms drop real low around 500-600 and car wants to cut out. Qjets and all carbs are still mysterious to me even after 15 years and have killed projects in the past. In park I am at around 1500-2000 rpm in gear around 900rpm. Running 93 octane fuel with Stabil ethanol treatment. The only vac line run in the car right now is from the rear manifold port and that is split between the brake booster, distributor, and carb. Please help!!! Forgot to add when I shut the car off it wants to spit and sputter and sometimes even backfires out tailpipe.
new vac advance HEI
air pump removed
feedback style qjet
