Looking back at the pics I see lots of issues with this thing. The choke is actually a hot air type, so it may be sluggish from rust. The EGR is not hooked up. There is what looks to be a broken thermal vacuum switch on the water crossover, so certain functions are disabled. There is a red 10 gauge wire and weatherpack connector just laying on the side- what is that for? And I especially don't like the rubber fuel line snaking around the front of the motor. YIKES! And then there is the indicated vacuum leak or internal carb issue. I would find and fix everything wrong/missing and only then make a determination of the carburetor. Then if it needs a rebuild you will be back in business. But if you want to avoid all that and take the "easy" way out then you would need a comparable non-computer Q-jet from an earlier model. Don't waste your time trying to force an aftermarket carb to work- it will drive you crazy. You will also need a non-computer HEI from a similar earlier motor. Try finding those and if you can get them reasonably cheap then I say go for it.
