quarter window
squinky33
33
6
49
Dallas,Texas
Hello I'm in da process of turning my 84 regal into a GN clone, my car has a vinyl top that i have removed. Does the side quarter window have a rubber seal around it because mind doesn't. Just wondering 8)
no not the ones for the vinyl top.u are gona need to find 1/4 glass for a hard top.those are the ones u need 8)
Ok I really don't want 2 take my 1/4 window out is there any that I can put a weatherstrip or something like black silicone caulk, please give me some advice :shock:
check out 3M's website. They have some really good stuff to use. I took my vinyl off and didn't replace the glass. Get some of the caulk/sealant that is in like a bar or stick. What I did was put no hardening lengths of it between the metal and glass and then put hardening lengths on top of that. On the inside I put a bead of black silicone on and will probably fashion me a finishing molding strip out of something to make it "perty". Check on ebay to get the supplies. I did and saved a ton of cash. Hope that helps.
Im really cheap so i just cut the top around the window with a razor blade then trimmed the excess away. It looks ok to me
