You may want to take a good look at that gas tank. Sounds like you may have a hole in it.
I have an '85 Monte with the stock 14" steelies and the 305. When I bought the car I averaged about 8-9 MPG with the set of 1987 snow tires (that still held air!) that it came with. I had to replace them with newer all season tires to pass inspection. These tires are significantly smaller in diameter than the snow tires, and at least one of them has a noticeable weep. Around that time my MPG dropped to an apalling 6, even after a carb tune-up to lean things out a bit. My question is this, is the smaller diameter the main reason behind the loss in economy, or is it the loss of tire pressure? (I pump the leaky one up every few days, it seems to have slowed over time). I can't get the leak fixed by any big box store, the shop that fitted them sold me old tires and no RMA certified place will touch them. Could it be that I need an alignment?
When's the last time you did plugs, wires, cap, rotor, timing? That would have more effect than the tires and 8-9mpg is a whole other batch of problems that's not good to start that don't include tires unless all four are different sizes and running 5psi.
