megaladon6 said:I wouldn't go over 2800 with your engine. I just bought a 3000 stall (for a 383 around 450+hp/tq). The highest rear gear (lowest # ratio) you would want to use with a 3000 stall is 3.40.
don't forget that your 383 has a lot more power and it's probably higher than his. he has a very mild cam and only 9:cr. i think 2800 will still be too high.
i'd call or email some good converter and cam manufacturers and ask them. they can figure out what stall and rear gear will work best. you will need the full specs of the part number of the cam and engine.
You don't think the 2500 stall would be perfect? I think it would. I mean, we can find cam specs and put numbers into calculators but for an engine that (guessing) redlines at around 5000, 2500 should be making some good power. And as the last post said, the posted stall is just a ballpark. It'll stall a little less than that with his set up. My guess is he won't be less than 2500 rpm on the highway going about 60-70
But you're right the cam company should be able to recommend just about anything, that's the first place to go
