I got mine for $10 at a U-Pull-It yard on half-off day. Dollar-for-dollar one of the best upgrades I've made so far.
malibu80 said:Swap completed. Alot more road feel and tighter. I'm having problems finding the info on the pump mods. Apparently when you change over to the quick ratio box, giving you higher effort and faster ratio it requires a little boost in maximum pressure and flow to help it turn smoothly and quickly under all conditions. On the back of the pump where the high pressure line threads into a fitting, that fitting needs to be changed out. This fitting on our G body vehicles has a smaller orifice than the fitting from a quick ratio pump. The fitting part number is 26009894. When you take this fitting off, you'll find a spring. This spring has to be changed out also.The g body spring is taller than the one that is going to be replaced. Spring part number is 5688037. Once that comes out, there's what they call the valve assembly that comes out next. At one end of the valve assemby is a screen. Its at this end that you take a cresent wrench and take the valve apart to remove the 2 washers. Mod completed. Sorry, I should have taken pics of this mod. I'll try to find the web page I got the info from. It had pixs of the parts needed as compared to g body pump parts.
