quick survey question/need advice
oldtinsmith said:
aaaaaah thank-a-you Master joe_padavano!
X2 on every thing you said. When I said to torque with suspension under load, I should have added that doing so ties the bushings in the neutral flex position. That way the bushings don't over flex during bound and rebound.
Doug
if they use polyurethane bushings there is no need to set them up under load....
