Is there an electric pump that doesn't thump so much you can hear it inside the car? I have a chepo one that is loud even though it is mounted on rubber shock mounts to isolate it from the frame as well as rubber hoses to shield transfering pulses to the hard lines but to no avail! Maybe mounting somewhere else on a standalone bracket may be the way to go. Ideas anyone.
Either in-tank or go "double standoff" by utilizing rubber mounts to hold the pump to a bracket and more rubber mounts between that bracket and the frame. You could try using a plastic CD ignition mount as a bracket, and they're available with threaded inserts pre-installed. Making your own would be just as easy.
Here is a pic of how I'll mount my ignition using two sets of rubber standoffs purchased online to eliminate vibration. I've placed an extra one right up front to see clearly. These standoffs have threaded ends but they are NOT a single solid rod- each end is independent of the other. By using two sets I imagine that the hum of your fuel pump would hardly be transferred to the frame and would be much quieter.
Pay no attention to the extra washers and such, it's just my way of not losing them.
Make sure your hard lines are mounted firmly with rubber insulated mounts. The lines can resonate terribly, especially if contacting the body anywhere.
Another option is a long shot, but try beefing up your ground at the pump, make sure you're getting proper voltage at the fuel pump. DC motors can get noisier than they should be if the power supply is lacking.
I have from the crossmember to the pump isolated the hard line with rubber at the clamps, that did improve some but it is the thumping sound as you can hear the pitch change as the pump primes. Metal lines can really amplify noise! I'm going to try another pump. Pump is well grounded, I don't think that has any bearing on noise.
I run a facet, they’re quiet enough you can’t hear it over the exhaust and they last many many many times longer than a little square Mr. gasket/Edelbrock/whoever pumps. The facets about twice what that Mr. gasket pump cost but I’ve used several of them and never had one fail
Mallory 140 used to be the best for this. Didn't have too many small pumps recently. Had a Magnafuel 500 pump in my race car. You could hear that thing running over 4" open headers of 1000 hp engine!!!
