I guess I'm going to have to run a wire up to the front and tap into a 12v source. So much for plug and play with this Racetronix harness. Why hasn't anybody on any forum anywhere stated you gotta do this with a non GN setup as its kinda important.....
Just received my pump/sending unit. That return line looks awefully restricting on the end. Idealy it 'should' be 3/8 and this thing is only 5/16 with the nipple end being even smaller. How is this NOT going to restrict the return fuel?
I'm sure it's plenty big to return the amount of fuel an EFI needs but I'm skeptical this will be big enough to return the amount of fuel a carb setup would need even if running a 3/8 return line.....
working good for me the last few years is all I can say, after all it does state it's for a GN... I chose it because I was converting from carb to efi and wanted proven system. as for the fuel pump I chose the AN style fitting unit and hopefully it keeps up with my planned upgrades!
