I would like to install a marine grade battery cut-off switch in my wagon since it tends to sit for long periods. But then the radio pre-sets get lost. I could wire the memory only to the battery while the car is dormant, but then I risk draining the battery if I let it go too long. When I disconnect the battery for any kind of service I attach a 9 volt battery to the cables to save the radio memory. Is there something like that, maybe a low voltage Lithium Ion battery that would keep the memory alive, then get recharged when I run the car? If it was a boat, I'd say wire the radio (and bilge pump) to a deep cycle battery to sacrifice, and have a separate starting battery to start the motor and recharge both. But dual batteries in a car is a bit much.
