442 Rally Gauge Problems
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Recently purchased a 1987 Cutlass Supreme 442. The gauges worked properly until a few days ago, when everything stopped working except the tach. After a few minutes, the gauges started functioning correctly and I figured it was due to the cold, wet weather. Today, the same thing happened, but the coolant gauge started working and nothing else. The coolant gauge continued to climb up to 220 very quickly, so I shut the car off. I felt the upper coolant hose (luke warm) and the rocker cover (luke warm). I'm thinking it is a rally cluster/dash problem, but the coolant gauge has me stumped. Can the electrical connections to the gauge cluster be the problem or is it something else? If it's the gauge cluster, any tips on removal/repair? Any assistance is appreciated.
techg8
475
342
coincidentally I am working on the rally gages on my 84 HO.
I came across this video that I thought was quite good regarding fixing common problems with the gages
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
That's wild. I just looked it up and watched it a few minutes ago. Thanks for the info anyway. It may be time to consider rebuild, replace, or upgrade to digital. Anyone have a digital upgraded gauge cluster that they'd recommend so I can consider my options?
Mike T
112
133
Baton Rouge, LA
I'm not a big electrical guy but I would think that for all the gauges to go out at once, it would have to be a common ground issue. I had the same problem with a cranky old 78 Malibu and if memory serves, it was a ground wire.
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Thanks for the info. After researching, I found a common problem to the rally gauge cluster is a ground wire coming loose or losing contact, but none of the research, that I've done, describes where the ground wire is specifically located on the back of the cluster. Most ground wires, that I've seen, are black but not always the case. Hopefully, someone on the forum will know from their experience of removing the gauge cluster.
84 W40
582
793
I would first check the ground strap in back of the engine driver side to the fire wall.
84 W40
582
793
When you do find it, take it off clean the ends of it. Where it bolts to the fire wall clean it to bare metal
JAMES L EUBANK
Feb 18, 2018
60
38
CLARKSBURG, WV
Thanks. I usually seal the ends of large braided grounds with rubber silicone. Is the wire the large braided type, and is this ground the primary ground for the gauge cluster?
84 W40
582
793
Yes its the large braided type. Its one the main ground wires to the body. It supplies ground to most of electrical components not just your cluster. If you look at your gas tank it has one on it and the other end is screwed into the body but smaller.
