Yuppppp.hahaha 40 ehhh I'll use it for gas money ! HahahaThoses riff raff are nice but 40 buxx a set.................dammmmmmmmmmmmmmmm
I went to chafazone (autozon) and they have a greas needle adapter. Looks just like a needle to put air in a sports ball? Wonder if that should be the easiest .I just under my car .I can! Get to itMaybe try making an extension piece using a piece of old steel fuel line or something similar tubing to be able to fit between there. Kinda like the guy on the B-body forum did.
And again, it depends on how accessible the ABS sensor end is.
It sounds like that apparatus may take you awhile to pump a sufficient amount of grease in the hubs.I went to chafazone (autozon) and they have a greas needle adapter. Looks just like a needle to put air in a sports ball? Wonder if that should be the easiest .I just under my car .I can! Get to it
It's this oneIt sounds like that apparatus may take you awhile to pump a sufficient amount of grease in the hubs.
If you can post a pic of what it looks like, or a link to the product.
Thank you. It looks like a device meant for smaller jobs...speedo cables, etc.It's this one
True .thinking to snip the end .if not just gonna get a carb hose that fits in the and a zink fitting on the other end lolThank you. It looks like a device meant for smaller jobs...speedo cables, etc.
....or you could do what the guy in the classB link did. Using a small piece of tubing, or pipe and screwing a Zerk fitting into the end. It looks like the tubing he used had the end closed off and drilled a small hole near the end for the grease to escape.True .thinking to snip the end .if not just gonna get a carb hose that fits in the and a zink fitting on the other end lol
